Discuss Radiator leak from top in the Central Heating Forum area at PlumbersForums.net
So this radiator is only just over one year old and have noticed it started leaking from the top, and rust started forming.
I think it's a Kudox radiator, obviously low quality. My plumber bought from Screwfix and him and I have fallen out so calling him back is not an option. Also I suppose there is some warranty with these radiators, but if I don't have the receipts as he bought them all then I can't get a replacement can I?
Now, luckily I have this British Gas homecare 4 cover, with a £60 excess and radiators included. Does anyone know what they are going to do about it - will they replace it or simply try to temporarily fix it and then have the same problem again a month down the line?
Thanks!
It not a leak on the radiator.
It a leak from the plug connection.
It's not a big issue, so if you aren't speaking to your plumber - call your insurance to repair.
Most likely they will tighten or replace the plug - not the radiator
New radiator cap.
Or you could just replace the o ring.
Valve at bottom of rad looks fairly new, I'd recommend having a go yourself, if the valves at the bottom hold its a 5 minute job for anyone with an adjustable spanner and a rag.
Are you game?
Edit or just give it a nip up first?
Very unlikely to get any joy from BG
Thanks!
Its a diy fix. Close off both valves either side of this rad just to be safe. Undo the naughty radiator blank, clean up around the thread and tighten up again, open the valves test, if still leaks then repeat process but use new Rubber ring or PTFe tape
or sillycone sealant ..all will be ok then. centralheatking
You guys blind ^^^^^^^^^ , its rusty , fixing the leak will not stop the rust .
To the op , yes as above for fixing the leak , with the plug out I would rub the rust off with some production paper and use some hammerite to paint the afected area.
I generally use a de-burring tool to clean the face of the thread on all radiator connections,
I have found that the powder coating, if not removed, can cut into the rubber o-ring and cause leaks.
Probably the situation in this case.
Mind you, the tone of the post was a little awkward.
Blaming Plumber and cheap radiators for the issue and wanting a new Rad.
If one of my customers had this problem, I would just fix it free of charge - if they were decent!
But would you supply micky mouse radiators in the first place ..I think not. chking
Reply to Radiator leak from top in the Central Heating Forum area at PlumbersForums.net
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi everyone, I have taken out the heat exchanger because a tiny leak was found around the red gasket at the top of the heat exchanger of a...
Hi everyone, I am looking to bleed the radiators in my rented flat as winter is now starting to kick in and want things to work as efficiently as...
1K
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
