Discuss Radiator installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Blimpy
First daft question for the knowledgeable.
How acceptable is it to install a new radiator on the other side of a wall to an existing radiator, T'ing off the flow and return from the tails to the existing rad??
Is this a no no or just reducing the efficiency of both rads?
Hello Blimpy,
its a good question, not daft.
it all depends on the size of pipes, size of radiators, number of radiators on the same pipe run etc.
if the flow rate or heat capacity of the pipe is not sufficient for the demand then your radiators will not work properly.
also the rest of the system would likely need balancing because of the addition.
Reply to Radiator installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator...
