Discuss Purchasing Taps - Low or High Pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
UnderPressure
HAm seeking some advice with purchasing new taps. I am told that due to the age of my property and design of my gravity fed water system, it is imperative that I purchase low pressure taps for my new bathroom/ensuite etc.
What constitutes a low pressure versus high pressure tap? What is considered to be low pressure? What is considered to be high pressure?
Can anyone make any recommendations at to manufacturers of good quality "low pressure" mixer taps for handbasins?
Thanks very much
Ask in the merchants where you are buying. Their catalogues will give pressure ratings for taps. if you want good quality you'll have to pay for it. Buy a cheap tap and it will not last long. Go for an established manufacturer rather than cheap foreign imports from the sheds.
Mike
Mike
Can you recommend an established manufacturer of good quality - low pressure mixer taps?
What are "the sheds?". I need to know in order to be sure I avoid them :)
Regards
Paul
Taps= Armitage Shanks, Bristan, Pegler.
Sheds are the DIY sheds B&Q, Wickes etc.
Mike
Careful buying taps. In the sheds at one time you could buy taps that where not to standard. There was no law to prevent a company selling such taps. But there was if you fitted them. Check the WRc site, they have great big lists of acceptable stuff.
We had loads of problems at one time with people going to the likes of B and Q fitting there own taps and after a short while they would leak like mad from the packing gland. Breaking them down showed nothing wrong, they just could not stand the pressure in the UK. More so now with combis supplying the hot at mains pressures.
Best get a good make like those mentioned or those on the WRc list and shop around for best prices. Shanks and Armitage are really good but can be pricey.
And don't forget your ball o flows and nrv's if required.
Thanks fellas for the advice. Will look for the brands you recommend
Bernie: I found the WRc site but found no lists. Do you have the URL to point me in the right place? Thanks
taps are taps - hi or low pressure dont really matter - the old kitchen tap in yer kitchen will normally be under mains pressure - does it blow up ??
if u want to gothe way usa is going get disc taps or if u are on about showertaps get a power shower fitted - job done
Thanks very much
Low pressure is generally around 0.2bar and high pressure is generally a minimum of 1.0-1.5bar.
Some manufacturers only offer high pressure taps as this is what is used on the continent. In the uk, like yourself a lot of people have gravity fed systems which is why you need low pressure.
thanks
thanks
Aaron..appreciate your input but do not link to website until things are sorted....
thanks dave..
taps are not the same,we have low pressure and high pressure taps
The kitchen cold may be on the mains,the hot could be low pressure from tank
'does it blow up'
when we talk about high pressure taps and low pressure taps,we are not talking about the pressure the tap can withstand but the size of the opening through the tap to allow better flow rate,the bigger the openings the better the flow rate through the tap when on low pressure
Yes Puddles right.
It should just be a case of low pressure has a bigger hole for the water to come out of.
Reply to Purchasing Taps - Low or High Pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
