Discuss Pulsacoil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Hello
Does anyone have experience with Pulsacoil please?
My tenant is saying pressure lost & can't even have a shower. Shower valve new last August
I'm waiting for her to tell me if the water is hot etc.
Any initial thoughts?
Thx. Rct
If you get stuck I believe there is a guy in Reading that specialises in them.
Cheers. I've never worked on one. Trying to figure out what the issue may be but the tenants not speaking the queens English!
If a water pressure issue I'd check the strainer/flow regulator on the cold inlet.
The only other thing I can think of would be a scaled plate heat exchanger. Disconnect inlet of plate and run into bucket to check there's good flow in. Disconnect outlet of plate and run into a bucket to see if the flow restriction is the plate...
Reply to Pulsacoil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
