Discuss propane gas bottle regulator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Boyler
I've a propane gas bottle with a regulator that I cannot remove. It's a red one with a half turn valve on it (Number 634PR) from cavagna group. Any ideas on how to remove. Bet you it's something simple,
With the fear of stating the obvious. If threaded? Undoing will be in a clock wise direction.
no i tried that both ways to no avail. bit of a head wreaker cause you would think it would be something so simple but just cant get it
found out how to get a picture up, so any ideas how to get this head off
check on the nut. if it has a slot on it, it will be reverse thread.
its a clip on usually theres a position opposite to on which allows it to come of failing that disconnect the hose and take bottle and reg to your dealer who will know which way is which i had the same problem and local gas supplirer had it of in minutes
dosnt look like the hose needs much work to "disconnect" it !!
EEK!
Not even a jubilee clip on the gas hose!!
Defo looks like a clip on regulator. Moving lever should do it.
Good fortune
alright lads relax there is no jubilee because we cant get the bloody head of it, it has not been used but will slap one on when we figure out how to get it off, i also took the hose off and its not reverse thread.
Must admit I had one something like this once. Same problem could not get the regulator off at first.
Unfortunately it did come off but I wasn't watching how it did, just fiddling with it out of desperation.
EEK!
Good fortune
dont know if theyve changed the set up but when i was at school all the bunsen burners were push fit onto a gas tap nozzle you could light the tap to shoot flames acrss the desks
this looks like a calor type portable fire regulator you may find the lever at the front 3 way i.e on-off-remove and seem to recall you may need to apply downward pressure and twist 180degrees not sure if clockwise or anti clockwise good luck and be careful regards tunpin....:)
Reply to propane gas bottle regulator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
