Discuss Problem with Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dan_the_plumber
Hello all.
I’ve got a problem with 105he driving me mad.
When you switch boiler on and set heating demand the pump starts for 1-2 seconds then clicks out, then starts again, then clicks out again, then starts again, over and over again.
I’ve done whole lot of electrical tests. I phoned Baxi and they told me it wS the PCB at fault. I agreed with this so replaced the PCB and guess what...The same fault.
I wondered if anyone could tell me what the fault might be please?
Dan :)
The only reason I say that is because I had a similar fault on a 105. A few of my associates went to it but couldn’t find the issue I got an invitation to deal with it after checking the thermistors (just connecting them to the leads) the boiler sprung back in to life.
From looking at the diagram have you tried to remove the flue overheat sensor below the sensor there is a nut. Remove the nut using your u gauge tube blow in to that hole. Any crap in there can cause a lot of issues.
At the same time check the flue overheat stat (try linking it out).
There is actually a fair bit of build up around that nut.
Passed a continuity test though. I might well try cleaning it out, see if that helps, Thanks :)
Reply to Problem with Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
Baxi 105he fault code blocked condensate trap? Removed terminals disconnected the pipes undid fixings removed trap and gave it a good clean out then refitted? Boiler still showing same fault code after a lot of head scratching I changed the terminals over from there original positions on the...
David Tait
Hi everyone, I'm hoping to get some advice on an issue I'm having with my Vaillant Ecotec Pro 24 boiler (R1 PCB). It was installed in 2013 and has worked perfectly up until this week. When the boiler does start, it runs for a few seconds, makes some noises, and then shuts down again. I've...
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip coming from the black nylon plastic drain plug at the back of the boiler which is accessible from the underneath. It does not appear to be from the thread...
