Discuss pricing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
13jmc13
okay ive been welding for the last few years and i now am going to fall back on my plumbing for extra cash. trouble is its been that long i dont know what to charge any more, i have a few kitchen fitters who will use me, but i dont want to be quoting prices from 4 years ago. this willl be my first attempt at this solo, in other words i never priced jobs in the first place it was always my boss ! it will be disconnect kitchen sink, slight if any pipework alterations, and re-connect new sink and taps and so on. any ideas folks :confused:
hi, spot on there.
i would keep the prices you charged 4 years ago as this will keep you competitive for the work thats available now as its a little thin on the ground.
good lick
its thin on the ground all round my only fear is coming in so low that it may make the kitchen guys wary of the quality of the work, my thinking behind this is small jobs are easier managed and if lucky enough think i could make more doing two small jobs in one day than one big one would 70 sound about right for to disconnect one day and reconnect when new kitchen is installed ?
I think £70 is fine. Travel to the house, 30 minutes, not being able to turn the hot water off because the valve is seized, stopcock not been used in 20 years and is a struggle. Not being able to turn off from the road etc.
Putting isolators on the hw & cw and don't you just know the waste is going to need some work because it won't line up.
Its never just a case of disconnecting and re-connecting.
it wont be as simple as disconnecting and re-connecting as secret squrrel says it may involve a lot more - core drilling new waste hole, re-allign pipework - iso valves and new waste 70 would be my labour charge for 2 visits removal and refitting, 20 materials and 30 if i had to drill hole.
thanks everyone who replied to my post your input is greatley appreciated so far i have agreed a set price with 3 kitchen outlets they are as follows £70 plus materials for one outlet and £120 for the other two who i will provide the pipe valves etc in the price. i hope this may be of some use to someone else in the same position as me.
Reply to pricing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
