Dannyparty92
I know that 1 metre = 0.1 bar so say if you have a cistern in a loft and a straight drop of pipe down 10 metres the pressure at that outlet will be 1 bar of pressure assuming its a straight drop with no fittings restricting the flow. Is this the same as working the pressure out at a point and if there's three metres of pipe going up then will the pressure be 0.3 bar below the pressure originally. Also is this rule the same for 15/22 mm pipe sizes. And also do you increase the distance of a pipe run by what fittings Are including in the run for the purpose of working the pressure out? Thank you in advance for any answers .
