L
lelehaine
Hello, i have a theoretical question:
Let's say i have a tap served by a pipe running horizontally for 50 meters. The pipe is served by the main water line through a ball valve. Both the pipe and the ball valve are 15mm in diameter.
As far as i know, there's a constant pressure drop along the pipe, related to its diameter.
I would like to know if replacing the pipe with a 22mm one, while maintaining the ball valve and tap, would make any sense in trying to reduce the pressure drop.
In other words, do the ball valve and tap are the bottle neck for the water flow rate, regardless of the connecting pipe diameter?
I hope it makes sense to you, sorry for not being a native english speaker!
Thanks!!!
Thanks!!!
