A
allwright
Does it matter weather i connect the unit to rad pipes or is it better connecting to the pump on the boiler
Discuss Powerflushing combinatin boiler and rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
depends what you mean if its the primary side yes if its the dhw side no for that you have to connect to the boiler tailscan you de-scale secondary heat exchanger just as well using rad pipes
never used one so cant saysteve the plumber and newbi, what do you think about using kamco pump adapter on combination boilers
Any of you guys tried the Norstrom Proflush machine? I'm buying a flusher in the next week or two and have read they are the best.
Reply to Powerflushing combinatin boiler and rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
