E
efficient
which is the best Kamco or Magna cleanse ?
Discuss powerflush machines in the Plumbing Jobs | The Job-board area at PlumbersForums.net
One is a power flush, the other is a filter systemwhich is the best Kamco or Magna cleanse ?
As Vern has said, Kamco make a power flushing machine, ADEY make the Magna cleanse which is a powerful magnetic filter, 2 entirely different things.
Hi Ray I have a Magnacleanse unit it's a filter, well 2 with 2 hoses with camlocks, 2 different beastsHi CES
I think the OP is talking about the MagnacleanSE not the Magnaclean.
The Magnacleanse is a flushing tool, but not a power flusher. As I recall, it uses the system circulator to create flow round the system, and comes with a drill mounted agitator to bang the radiators.
It is designed to fit the Magnaclean filter connections.
Its way cheaper than a Kamco, but without its own pump, so I can see limitations.
OOps - sorry - reread your post properly - if that was what you meant, ignore me!
Ray,Sorry vern - I read the posts too quickly!
Adey market the magnacleanse as a better alternative to powerflushing. What's your take on that?
They do indeed and also make it in black not clear for fernox tooKamco do their own magnetic filter to compliment their power flushing machines.
CombiMag magnetic power flushing filter
I agree Peter overpriced, it does speed it up as you cannot often dump quick enough so some magnetite does the rounds again, especially if you are reverse flushing rapidly etcThey look well made, but then I believe they are around £300.
But is it overkill? If the contaminated water has been drawn off the system, why not just dump it, rather than filtering it?
If the cleaner is pump around to get the magnetite into suspension, then why not pull out the water and dump it?
Unless of course someone wants to clean their radiators out without losing their inhibitor ... lol ... I think that's Super Green! :rolleyes2:
Reply to powerflush machines in the Plumbing Jobs | The Job-board area at PlumbersForums.net
