Discuss Power flushing chemicals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Hi, planning to powerflush a microbore system, it will be a cold flush as need to go through the pump head. Just asking what chemicals people are using, i have been using Adey recently does anyone get any better results using anything else on a cold flush?
Cheers!
adey fernox tbh most are the same stuff im sure of it
x800/mc5 or x400 mc3
Adey will be fine mate go with that mc4 run in the system for a week then mc1once the system has been hot flushed and cold flushed , fit a mag filter to that will pull the rest out good luck kop.
What products would you use prior the power flush a week earlier if there is no leaks but noise in the boiler ? Silencer ? Or x400
think you miss typed mc4 is leak sealer
Opps well spotted shaun heres a picture of what i meant to use appologies kop
if your in the trade williams this month have a special offer on adey chems
Reply to Power flushing chemicals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi i bought the house that Jack built and ohh has the heating been left to spoil. Prior to moving in 2 new firebird boilers were fitted, silver...
