Discuss Potterton statesman 45/50 nozzel size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
cant find the spec I need to service this boiler and I'm not planning in making two visits so getting info and parts ready but can't find any info on the nozzel size.Any advice would be appreciate.
This may Help... Ive got more or less all Oil Boiler Manuals Handy. . .
  • Potterton-Statesman 45-50L.pdf
  • PDF file.pdf
If you have OFTEC books or even their pocket guide it will show you how to calculate a suitable nozzle size and pressure depending on burner output needs. I did look online quickly but couldnt see the nozzle sizes etc in a manual.
Bare in mind a slightly bigger nozzle will require less pressure and a slightly smaller one will require more. Neither Tea-Break or I are wrong, weā€™ve just worked it out slightly differently, however too low a pressure and the fuel wonā€™t atomise properly
The RDB1 manual says 10bar Page 8 Table A for Kerosene.
https://www.rielloburners.co.uk/images/content/downloads/RDB1-2_2902489-18.pdf
And this should give you the nozzle needed: http://www.delavaninc.com/pdf/total_look.pdf
I think this relates to the generic pump pressure range.
The boiler in question is quite small 45/50.
Therefore the correct nozzle should be .45-.50.
As SJB correctly states, going below 100PSI is not recommended.
To return to the the original post. Without wishing to be condescending, this is all bread ā€˜n butter stuff for any oil engineer.
It's categoric at a maximum of 10bar, how many times do we see posts that say follow the manufacturers instructions, concerning pump pressure and nozzle size.
The Delavan catalogue on page 7 also says to find the correct nozzle:
GPH = BTU Input / 140,000 or GPH = BTU Output/(Efficiency %) x 140,000
Ten bar is really too high and is a max limit for oil pumps on kerosine I believe. Higher can damage the pump
7 to 9 bar is range.
Diesel can be higher.
On outputs you will find the nozzle size will closely match x 1000 the btus with kerosine.
(.75 nozzle at 7 or 8 bar kerosine usually going to give 75,000 btus or more)
If you read burner manuals especially Riello it clearly states that itā€™s 10 bar max for kerosene, for the very reasons Best has mentioned above, class D is usually higher pressure and different nozzles/patterns. I didnā€™t feel the need to mention this before as anyone working with these burners should know this and study all sorts of manuals. As best said usual range is between 7-9 bar, but like I said too low and youā€™ll get atomisation and combustion problems.
If you havenā€™t got one already Inverness phone OFTEC and buy their pocket guide, if I remember correctly itā€™s about Ā£5 plus delivery. It has these calculations in there plus all the other important information for checking tanks etc etc.
That's what I said 10bar maximum, the OP posted they did not have the manual for the unit, so I posted what I thought was a helpful link to the burner and nozzle calculations, the criticism's where unnecessary, be helpful by all means, but don't denigrate others for trying to help.
To obtain 0.75 from 75,000 you would need to divide by 100,000.
Lol! True! I did post that at 2.40 am. :)
Although tbh I just always have in my head to add 3 zeros to the smaller nozzles size (without thinking of the position of the point)
But as you say, multiply by 100,000.
Just was something I always noticed with boilers on kerosine and still applies as a rough guide despite the increase in efficiency in HE boilers.
Best you say multiply smaller nozzle size by 100000 to get btuā€™s. At what pressure is this assuming? And I assume this figure is burner input, not boiler output or efficiency must be taken into consideration?
Only saying that as a very rough estimate of boiler output for kerosine and at 7 bar or 8 max oil pressure.
At 9 bar the output will be higher.
Just really judging that on all boiler specs, of various types.
Nothing to rely on, but just an indication that a nozzle on a boiler you go to is wrong size.
Yeah I just done some examples on my EOGB calculator and what you say is a vary rough figure, depending on pressure and efficiency. Iā€™ll stick to what I know lol
Of course its correct, It's an international standard for all manufacturers that they quote the output of their nozzles in GPH at 100psi I should think that everyone on this thread knows that.
US gallons per hour at 100 psi, which always seem weird to me, but thatā€™s how it is
Our UK gallons is roughly .84 of a US gallon if Iā€™m not mistaken, but yes Best it relates to US measurement as I believe the pressure jet burner is originally an American invention
I also tend to think on oil output of a US gph nozzle approx same in our UK gph if oil pump is set at 8 bar.
US gph is at 100psi, so at 8 bar it is 120psi which is close to converting the US gallons output to our gallons.
So say a 1.0 nozzle at 100 psi will give .84 UK gph, but multiply by 1.2 (to raise to 8bar) will give approx 1.0 UK gph.
If that makes sense. :)
The first pressure jets where used to propel vehicles and where invented by the Russian N Teleshov in 1864, adapted by a Swedish inventor Martin Wiburg and eventually became the pressure jet burner.
Wow! Where did you find all that from?
A little confused there I think, a 1.0 nozzle at 100psi will give 1US gph or 0.84UK gph, got your UK and US mixed up, easy done, but as you say raise the pressure to 8bar (116psi) and it will give approximately 1UK gph.
Reply to Potterton statesman 45/50 nozzel size? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and Iā€™m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler pump menu for either 70% or 100%, so, is the pump set at either one of two fixed speed percentages or does the pump actually vary speed, (modulate)...
