Discuss Potterton Puma 80 Burner makes loud noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SatPal
When I open hot water tap the boiler fires and the burner makes a very loud sound. Can this sound be reduced? As the firing intensity sound is too loud.
Hi SatPal ... I think you'd need an GSEngineer to take a look at what's causing the noise. Does it occur when the heating is on too? There are many things that can cause a 'noise'!
As above Sat get a GSR engineer in.
Common fault I have with these boilers is explosive ignition and it will only get worse.(I am guessing from the description).
A qualified engineer is the only way forward, he has the knowledge and tools to check the appliance, in particular the low and high burner gas setings in your case.
Bob
call out a gsr engineer they will take one look at your puma then say its a heap(which it is)and quote for a new boiler sometimes the truth hurts
the local counsil's around by me fitted hundreds of theses 8-9 years ago, most have been replaced in last few years. how old is the boiler? may be time to let it rest in peace!
Reply to Potterton Puma 80 Burner makes loud noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
