Discuss plumbing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
indigo
I recently tried to replace the diaphragm on a multi point gas water heater. I think it was a chaufetau( Spelling?) I could not get the diaphragm housing to seal. I made several attempts to no avail. I then put the housings together without the diaphragm and I could a gap of about 0.7mm.
Is this common for this heater? any suggestions on how I could have resolved the problem?
are you sure you have the right diaphragm, or is facing the right way round :p, any time i have ever changed a diaphragm it is an easy fit with no leaks, but i do remember some of the old vokera ones were slightly different and leaked if you got the wrong one
The diaphragm fits into the housing rim,should be no problem,maybe you have wrong diaphragm or one made in china,never had a problem
The diaphragm was correct. In fact I bought two from a reputable source.Including a new housing rim. But neither worked. I was surprised, I have never had this problem with other boilers.
Reply to plumbing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
