Discuss Plug a 17mm OD Copper Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I found a 17mm OD pipe, which looks steely, in the walls of our house.
It's disconnected, but don't know where the other end connects to.
I want to plug it and plaster over it, any idea how to cap a 17mm pipe?
Many thanks,
Adam
Assuming this is 1940’s copper pipe, swage a 15mm copper fitting and take it onto a 15mm end stop. You won’t swage an end stop - fitting swaged, pipe, end stop. So you will need to cut into the wall, for a flush finish.
A better solution is to find the other end - compressed air and a good set of ears is good at that
Both a cork and swaging the pipe are great solutions, thanks all for your help.
I'm going to try swaging with an end stop, and if that won't work for some reason a cork will have to do. I will also search for the other end!
Reply to Plug a 17mm OD Copper Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
