Discuss Please help.... Installing a negative head pump. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If I install a negative head pump for 2 showers will it also power up to feed the positive head taps...
I've got a:
Stuart Turner Monsoon Shower Pump 2 bar Twin Impeller Negative Head
:sweatdrop:
Thanks in advance...
What you should do is take an independent feed from the cold water tank to the pump and an independent feed from the hot water cylinder to the pump.
Connect up the feeds to both showers to the pump and you now have a 2 pumped showers.
I don't understand why your asking about the taps.
Reply to Please help.... Installing a negative head pump. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
