Discuss Plastic tee fittings near boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, i'm installing a bathroom and need to install tee fittings into existing hot/colds. The best place to do this is near the boiler, however someone told me you cant use plastic pipe/fittings within a certain distance of the boiler. The best place for the tee would be about 2 feet away from the boiler, can i use plastic here?
min distance is 600mm but more is recommanded
Hi, you need to check the boiler manual as it will be stated in there the correct distance from the boiler you are permitted to use plastic. Most manufacturers state a minimum distance of 1 meter away from the boiler. But check the mi's to be sure.
Reply to Plastic tee fittings near boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
Hi new to the forum here and after some advise please. I have done a garage extension and need heating in the room. I am in a town house with no...
3K
Hi all, I've been researching and planning a job for my home the past few days and a few pieces of advice would be welcome to help me along the...
2K
