Discuss pex plumbing question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jameshudson45
My 69 Sovereign has a couple of copper water pipes that appear to be split/cracked I am assuming from not draining properly in the winter
It seems like favorite product used to repair is the pex product.
Does anyone know the recommended size used to connect to the original plumbing?
Do they make an easy connector to connect the copper pipe to the pex tubing.
I persume with good weather you have returned to your caravan or weekend escape
The existing pipework will most lightly be 15mm,fittings from pex or any plastic pipework are readily avalible,do not use plastic pipework within 1 meter of water heater
Reply to pex plumbing question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
