Discuss part L building control in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gaspastemania
Getting a bit fed up turning up at jobs to update systems etc to find out that previous plumbers have not fitted room stats , now i have done this in the past but under customers knowledge of not havinf that fitted or on my wall . Notedin MI'S and fair enough .But this i find is quite a common occurance and customer has never been infornmed on room stats soooooooo how do you go about dropping previous fitters in the muck so to speak ,,,,if you can at all ?
(to many plumbers in the game so time to remove the shocking ones)
in an ideal world you need to educate the customer so they know what the min requirements are and they can make sure thats what they get. Hard to tell people they need to spend more tho.
Just because it is a requirement if the custard refuses or cannot afford a upgrade. And all the contractor has been asked to do is a boiler swap. Then you cannot enforce that they have the upgrades
That was exactly what my local insp told me
Sent from my iPhone using Tapatalk
Its not that the customers i have come across lately are refusing they simply wasnt even told lol , i dont know maybe i'm being fussy .
Fed UP, try this.
I was asked to quote to move a 8 year old non condensing Suprima into a new extension, which included Planning and Building control involvement. I stated as the boiler move had to be Notified I could not move the boiler and a new boiler had to be installed.
The customer contacted the local Building Control office at the council, and was told by the local inspector that the boiler could be moved and did not have to be a condensing boiler!!
The gas safe register were then contacted by the building control inspector and it was agreed by them that it was unfair to expect a customer to have to have a new boiler after 8 years.
I walked away from the job shaking my head. What is the point of gas work notification if it can be deemed as unfair !!:banghead:
that is spot on you just get the custard to sign a disclaimer:nono:
A good engineer etc will or should strongly advise on fitting best practice controls regardless of extra cost. Some of this extra cost will be offset in years to come by having a properly set up, efficient system. But...at the end of the day you cannot force them to listen to your professional advice. Just note down that energy controls advise has been declined.
Fed UP, try this.
A boiler that is already registered at the property can be moved to different location without issue. You are not fitting and registering a new appliance, so it does not have to comply with latest guidelines. An 8 year old Suprima although not the best of boilers still has a few years left in it.
"A boiler that is already registered at the property can be moved to different location without issue. You are not fitting and registering a new appliance, so it does not have to comply with latest guidelines. An 8 year old Suprima although not the best of boilers still has a few years left in it."
Reading this months Gas Engineer there is an article on Building Regs advising "What needs to be reported"
Installation/ Replacement / Commissioning of : heating and hot water boilers ==== Reportable.
I cant see the difference between the boiler being new or old.
I would have moved the boiler and notified the installation, however would be unable to complete the online boiler details as it was non condensing.
Kev.
The boiler is already registered/commissioned for that property right! What if the custard wanted her boiler moved 2 meters to another wall in kitchen to facilitate her fancy new kitchen? You install and re-commission as per the regs. By your reckoning you need to register the boiler again??
I think that you are supposed to register it again if you move and commission it even within the same address.
i can't look it up now but I think it is around page 15 or so here about commissioninf fixed building services.
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADL1B_2010.pdf
It used to be that you could move a b rated boiler WITHIN the same address under 2006 building regs but I don't know if that changed under the new 2010 regs.
Without starting a row, I can only apply my actions from what I read, not an opinion from somebody who has opinions which may not hold up in court.
I started with BGas in 1986, Im not a newbie wet behind the ear, what people say and what the officials behind them say in court is another matter.
Kev.
I went on a honeywell training day recently and they said the customer can get the installer to return and bring it up to part l free of charge if they didn't get them to sign a disclaimer
That is very unlikely to happen if all they have is some mobile number for a guy with a white van. People pay their money and generally get the service they deserve for the cost.
How many times have you gone to a job and had the cust say something like i have a budget of £800.........Good luck.....see ya! (putting it politely!)
some pay good money though and think they are getting a proper job, if the guy registered the boiler couldnt they trace him that way?
How many have you gone to without a log book filled in? Probably +40 - 50% of what i see.
I really have little if any sympathy for most customers but there are always exceptions. I really hate know the price of everything value of nothing people usually mid 20's to 40 odds. The internet has a lot to answer for.
I do however have a soft spot for old people and as such generally i try to avoid them if i can. They are bad for my business but it is self inflicted (it is really a virtue instilled by my parents):)
Reply to part L building control in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, please help dont have a clue how to set this up. Ive recently installed a complete new central heating system in my house myself. The...
4K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
Hi all, I've got a cash-strapped church hall with a 2-year old Vaillant boiler. A timeclock was fitted by the original installer to the front of...
2K
O
    • Agree
  • Locked
hi guys, just came across this little note of Atag boilers. The new 'Boiler Plus' regulation comes into play next week, and we’re...
Hi, I'm a newbie and need some advice please. My 4 bed house has gas central heating with the Regular boiler (BG 330 set to 18Kw output) located...
3K
