Discuss Outside Tap Not Working.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have recently bought my first house and am trying to sort this out myself but I have absolutely no idea where to go next, so thought I would try asking here on the off chance someone might be able to guide me in the right direction!
We moved into the house about 3 months ago and the outside tap has been working just fine.
I tried to use the tap at the weekend and got nothing from it, not even a few drips. I took the tap apart and could see some stagnant water in the body of the tap. I have since taken the tap completely off and still nothing.
As far as I can tell (and please bear with me as I am definitely NOT a plumber), the plumbing is connected to the same pipework as the dishwasher which works absolutely fine and gets water, so I am completely stumped as to what I can do to try and fix this.
I have uploaded some pictures here to try and help explain:
IMG-5683
IMG-5684
IMG-5685
IMG-5686
The 1st 3rd and 4th pictures show the plumbing to the outside tap, and the 2nd picture shows the dishwasher connected.
If there is ANY advice at all you can give it would be really appreciated.
Sam
As Duncan suggests, it's likely that the silver coloured valve (double check valve with isolater) has failed and is jammed closed. However it could also be the pressure reducing valve with the pressure gauge attached has become completely blocked. I would be surprised if it is blocked badly enough to completely stop flow but it is possible I suppose.
It'd be worth checking the strainer in the pressure reducing valve. Turn off that stopcock first! The grey head unscrews anti-clockwise, using a spanner on the flats, and pulls out. It has a strainer on it which can be removed and rinsed under a tap if it is clogged up. Use running water and an old toothbrush to clean it if needed. Reassemble in reverse order, screwing it back on tight but don't go mad as it seals on an O-ring so needs to be snug but not white-knuckle tight.
Turn the water back on and test the outside tap. If it still doesn't work (or the strainer in the PRV was clear) it points to the double check valve with isolator being jammed closed in which case that will need replacing.
Finally, does the tap itself have check valves built in? They can be seen both at the tap spout and inside the tail of the tap if they are present.
Thats fantastic thank you I will try cleaning the pressure reducing valve first.
How difficult would it be to replace the double check valve myself, are they all a standard length? It looks like it would be simple enough to unscrew each end pull it out and then fit another....but I may be completely wrong?!
Yes I have just looked at the tap and it does seem to have some kind of valve either end.
Sam
Yes that's the correct type. There is no guarantee they will be the exact same length though but it looks close enough.
With regard to the tap, if it also has check valves built in they could also be jammed closed. Open the tap and see if you can blow through it in the same direction the water should flow. If you can then the problem is not with the tap itself. Strictly speaking you only need one double check valve to protect this system and you have a double check inside the house as it should be. The ones installed in the tap are surplus to requirements. If you end up needing a new tap, get one without the check valves built in. With a total of four on the feed it will cause some reduction in flow rates. That said if the tap is fine I'd stick with it.
Well I will give it a go...what could possibly go wrong!
I have already taken the tap completely off and there's still no flow so I do not think it is that.
Thank you all so much for your help, I will let you know how I get on..or will let you know how much I spent on an emergency plumber after I break everything haha!
Sam
Something like this maybe?
https://www.NoLinkingToThis/p/pegler-8028-isolating-check-valve-15mm/2059v?_requestid=167418
Yep that's what you need, also the Pegler are a good quality choice.
He's got no water coming out even with the tap completely removed so the blockage or broken valve must be elsewhere, doesn't hurt to give any checkvalves a clean though whilst everything is off however.
What is the kitchen tap like? Same as before? May be no need to strip down prv. Although not a waste of time to clean it, there may be debris in it.
Ahh, I am daft and didn't notice it went off and fed the kitchen tap as well! It's all pointing towards that double check/isolator valve then.
One possibility is that OP turned that double check/isolator off for some reason and when he opened it again, the head turned but it slipped on the spindle and didn't actually open the valve again. The little black lever is often made of plastic and they get rounded out and don't actually turn the spindle to open the valve, even though the handle moved.
To the OP, fortunately you have a stopcock very close to where you are working so you shouldn't have any actual disasters because you can always turn off the supply and call someone out if it comes to that.
As stigster stated it could be the plastic handle that hasn’t turned the valve, looking at that it’s the type we use on filling loops Altecnic make it, but ours are TP (plumb right). Wouldn’t hurt to put a quality one in its place. To try and repair without trying to damage anything or cause a flood is undo the screw that holds the black plastic lever in place, see if the metal piece is vertical or horizontal.
I had the valve closed initially, but then when the tap was completely off I turned it back to open and it has stayed open since, with nothing coming out..
Don't leave it like that if you are not watching it. If whatever is blocking the flow decides to move for some reason while you are out or asleep you could end up with a very large water bill or a lot of damage. Or both.
So have just finished swapping over the valve and everything is working perfectly with no leaks (although I will keep an eye on it!)...the olives were a pain to get off but used an adjustable spanner and it wasn't too long before they were off.
Thank you all so much for your help! See you next time something breaks!!
Thank you for the update.
Reply to Outside Tap Not Working.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
