blayedrunner
On Saturday i was taking my boy swimming in the van when a custard came up an asked if i could look at his small problem with his cylinder compression fitting. I said no problem see you Monday.......
Arrive Monday, see a few compression had come away an a bent pipe so fixed an thought this looks like damage from previous tenants (didn't know next bit)
Ok back story.... The house was rented an from Nov-Feb was left empty. The agents turned off the water.
Turn on the water, cistern fills up..... Water starts pouring down behind the walls in the down stairs toilet. Oh dear.....
This is just the beginning... pipe had split half way up wall, ripped plaster board wall out an fixed. Next shower leak, half way up pipe behind lovely tiles the pipe had a split, fixed. Central heating pipes under the floorboards had a split, fixed. Boiler heater exchanger has broken and has flooded the garage....
3 hours has turned into 5 days plus a boiler swap..... Thank god i was quiet this week. An thank you Lord of Snow an freezing weather.
Thats my ramble over, if you made it to the end well done hahahahahahaha
