Discuss Old toilet removal. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jackplumb
I have to replace an old toilet. it is cemented into the soil pipe, what is the best method of removal and what fittings to replace?
Can the cement 'collar' on the floor also be removed?
you will have to break the pan to get it out without dropping any down the drain first thing you want is thick gloves
mop out the water first then break away at the bottom of the trap then care fully work towards the drain pulling the china away as soon as you can see down into the drain shove some paper of a roled up rubbish sak into the drain to stop bits droppping down then knock the rest of the china inwards so you dont break the collar
its not the end of the world if you do but easier if you dont
usually your going to go back with a long tailed bent pan con so if the cement has stayed in collar just slide it through if not youl have to put strong mix sand and cement around it
if you have a wet and dry you can suck the water out to avoid flooding, of course it depends how you feel about sticking ya vac down the bog.
i take of the cistern then chisel it out with a strong flat driver and hammer (cement).
Reply to Old toilet removal. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
