Discuss Okay we've had the mistakes, how about the unexpected and unavoidable? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mike Jackson
I'll start with one about 4 months ago.
Pain in the neck job, relocate boiler from kitchen to airing cupboard above new cylinder. I drained and removed the old cylinder and boiler. Fitted the new boiler in the airing cupboard, fitted the cylinder and got the heating up and running. This was all done before refilling the cylinder as I wanted to heat test the new pipework under the cylinder.
On the third morning I reconnected the secondary side of the cylinder and turned the water back on. The cylinder filled an I heard the tell tale rush of water as it filled and heard the water running from the hot taps in the bathroom downstairs. I casually wandered downstairs to shut off the taps and was greeted by a waterfall emerging from the boxing over the bathroom door.
After shutting the water off I set about investigating the problem. It was a bit of a mystery as the boxing was a good ten feet from anywhere that I had been working. As I pulled the front off the boxing I got a face full of dead wasps, out with the henry to suck all the dead wasps up before the custards dog trod on one. As I pulled the rest of the boxing off I noticed something sparking within the boxing, off with the power.
There was a compression fitting within the boxing but that was fine, the water appeared to have come from where the pipe passed through the wall from the bedroom above. To get to the other side of this I had to move most of the furniture in the bedroom. I removed the boxing in the bedroom and cut out the suspect pipe. There was a 1/2" hole in the side of the pipe and the culprit was obvious as I pulled the pipe out.
Behind the pipe was an electric cable that used to feed the washing machine socket. Well actually there were the remnants of two cables one had been chewed completely in half and the other had the insulation chewed off exposing the live conductor. The scorching to the two cables showed that there had been a great deal of arcing taking place for quite a while. The hole in the pipe was adjacent to the exposed section of live conductor on the almost intact cable.
I assume that as I moved pipes in the airing cupboard it brought the pipe close enough to the cable for it to arc to the pipe and blow a hole in the pipe. Because flux tends to wreck my hands I wear gloves when I'm working a lot of the time no and I wonder if this saved me from getting a shock from the pipes. Amazingly none of the fuses had blown.
There aren't all that many jobs where you can be stressed, physically strained, filthy, ruin someone's house and kill yourself in one day.
a bloke i worked with while i was still an apprentise accidently cut through a copper covered pyro cable which was running under the floor into next door to supply there electrics. The cable was roughly 10mm in diameter and copper covered so looked like a 10mm copper pipe. It ran parallel to a 10mm gas pipe in the next board over and the guy mistook it for the gas pipe and put his hacksaw to it.
He got blown backwards and luckily did not die but his junior hacksaw did not live to see another day.
Not so much the unforeseen but a couple of coincidences. The first happened while I was repairing a downstairs WC in a large house. I had just refitted the cistern when I heard screams coming from the house. Someone shouted 'quick there is water pouring through the kitchen ceiling' my first thought was 'oh #### what I have I done this time?'
Went to investigate after some accusing stares from the householder. The source was an ensuite sink overflowing. The tap had been left running by the householders daughter !
Couple of weeks later during last years cold snap I was installing a bathroom and was just packing up for the day having installed the bath and WC. Once again screams and water pouring through kitchen ceiling - once again 'oh #### what now ?'
This time the rather sheepish householder happened to mention that he has been defrosting a frozen pipe with a warm air heater in the void above the kitchen. The law of sod dictated that the pipe defrosted and the three push fits that had been blown off were now free to flood the kitchen.
Many more examples of my mistakes, but it was nice to go from that sinking feeling to realising that this time it was not down to me.
Sent from my iPad using Tapatalk HD
Reply to Okay we've had the mistakes, how about the unexpected and unavoidable? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We had water leak from the laundry sink into the cupboard below, then flow down the hole cut for the pipes (the hole was on the floor of the...
James Auberon
J
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
