Discuss oil supply not getting to my boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
I started having issues with my heating and hot water, I thought I had ran out of oil, however, when I filled up with 400 litres, the guy told me that my 1000 litre tanks is completely full, so the issue was not oil tank being empty.
Now when I try to get the boiler to work, it seems oil is not getting to the boiler? on checking the filter, which is next to the boiler, I can see that there is some oil, but when it tries to ignite, I can't anything happening with the filter, eg oil being fed through to the burner
Any advice welcome please, as I don't know what to do
You need an experienced oil engineer. It could be any number of things, and once you start messing with these things you need to make sure the combustion is set correctly or you may kill yourself and your family.
Yes, my landlady is calling one, asher daughter tried everything she knew, but still no joy
Reply to oil supply not getting to my boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
A
My oil boiler is 2009 vintage. Just been serviced. Had a new tank fitted by approved fitter. I notice that the bottom of the tank is roughly on...
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
My firebird oil boiler hw supply is luke warm, but does heat up slightly when run if the ch is on at the same time. Is this a faulty diverter...
2K
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
