Discuss Obsolete Daryl Hydra classic 400 shower in the USA area at PlumbersForums.net
Hi - hope you can help. The on/off tap (part number 204543) on my Daryl Hydra classic shower has broken inside. I spoke to Kohler UK but they don’t stock the part. They recommended replacing the whole unit with a Amicio shower, but this would be chrome and my enclosure is in gold. Also on measuring mine is 8mm taller. I would appreciate any suggestions. Many thanks.
Hi just wondering if you managed to fix the shower or if not I could really do with a replacement part that's snapped off if I could buy the part from you? It's the plastic flow control valve for the water feed pipes that screws into the thermostat
Reply to Obsolete Daryl Hydra classic 400 shower in the USA area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
