Discuss Notching in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bassmonster
Hi all,
i would like to know how much i can notch into the joists running 22mm pipes.
the joist size is 7" X 2".
am i OK to use the talon clips as in pics as this would require me to go notch at least 50mm x 75mm or should i go for nail on clips which are more shallow
thanks.
nail ons with rap to stop squeaking and 1/8th the depth and for holes from center 1/4
builing regs say 1/8th so
175mm/8 =21.8mm
nail clips or nothing
also is that an outside wall?
thanks for the replies..
yes, outside wall which will be part of a kitchen extension.
21.88 will obviously be not enough......
when you say 1/4 from center, do mean 1 quarter of an inch?
1/4 of the total depth for a hole needs to be in the center tho
but the problem your going to get due to outside wall need need to take the span into it
the notch already there looks sufficient size anyway??
Why do you need to clip the pipes anyhow? If they are heating pipes they will not be going anywhere once you join them all up, - so temporary clips would suffice if you really need.
If they have to be clipped well, then you could put timber between the joists, at correct depth to suit clips.
I don't use clips in notches, I just wrap them. Follow the above guide for depths etc
The old central heating system was run with 15mm. I think I'll leave out the clips as if I notch another couple mm it will be enough for the pipes to sit nicely.
Thank you all for you replies... Much appreciated :)
Not being funny, but if we all followed the building regs to the word then we would not be able to install a system or notch anywhere lol! Like the above example which came out at 21.8mm lol!!
Never seen talons fitted in a notch! Use nails on where needed...
so you can notch them for a 22mm pipe with clearance just :)
A 22mm pipe with fittings & wrap ain't gonna fit in a 21.8mm notch surely lol?? Creaky floorboard anyone :p
well who says your tape is dead on im sure you could get it to 25mm quiet easy :D
A couple of strokes with half round rasp would allow for pipe + wrap and locate pipe in notch eliminating need for clips. If clips are specified, then use open type fixed to 50 X 38 timber screwed to side of joist.
Agree
Reply to Notching in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
Hi. What would you recommend for pipe support whilst running 15mm central heating pipes parallel to floor joists? My idea is to screw wood...
2K
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
