Discuss Noise from electric boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mchoa
Hi guys,
Hoping some of you smart people can figure this one out because I can't.
Recently fitted an Amptec electric flow boiler and is has been making a noise that sounds exactly like a ship fog horn. It is a mains fed system and the boiler feeds a cylinder and wet rad system. A PRV is fitted so I don't think it's too high pressure at the valves.
I've heard about cases where other gas boilers made this noise due to incorrect gas/air ratio but naturally this doesn't apply here.
The only other thing I can think of is the pump is running too slowly/ getting clogged causing kettling but it's a different noise.
Hoping there are some bright sparks out there
Thanks,
Reply to Noise from electric boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
