Discuss No hot water from Shower after changing pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
We noticed yesterday that there was a damp stain on the bedroom ceiling. I had a look in the loft and there was a slow drip coming from the shower pump. It was coming from the pump itself rather than the water connections so I replaced it with a like for like
Twin Impeller Shower Pump 1.5 Bar
All seemed to go fine and the leak is now gone but although the pump is kicking in, it's only doing so for cold water - Hot water is not being pumped through.
It can't be that I've forgotten to turn the isolator back on because there wasn't one for hot, only cold and I had to drain down the system.
I'm wondering if it could be an airlock? If so, how can I fix?
The system is traditional gravity fed with a cold water tank in the loft and a hot water cylinder in the airing cupboard. The shower pump only feeds a shower in the en suite. The main bathroom only has a bath.
thanks
Maybe if you have one put the shower hose at its lowest point in the tray maybe with the pump turned off you may get the air out when the water comes out
Legend!!
Yeah I tried that with the shower head disconnected - it spluttered for a bit and started working again so clearly was an airlock.
Thanks for saving me having to spend more time messing round in the loft with such and easy fix.
Reply to No hot water from Shower after changing pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
PSxxxxxx
