Discuss No downstairs heating ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hello guys,
Could anyone give me some sort of idea I am having a Vaillant ecotec plus 438
4 story house
Downstairs basement excavated is the boiler and the hot water cylinder.
The central heating works everywhere apart from downstairs which are 5 rads cast iron column rads with restored old brass valves.
Boiler works well
Zone valves works fine
How comes it doesn’t ciculate? What should be checking?
I tried to turn all rads off but no effect
What zone valves are there?
2 port zone valves for hot water, ch, and ufh
According to the owner it has worked before. I am a little stuck here as I don’t seem to find a solution. Everywhere else in the house it’s roasting hot therefore I tried turning the valves off and distribute the heat into the ones which don’t work. Nothing has changed.
I take it they have all been bled!
Aside from that I'd electrically isolate the non used zone valves, shut all the other rads down, shut down the bypass, open up the rads totally and see if you can force water through downstairs. Worse case is once all that's done pop the bleed screws out to see what's occurring.
Call me cynical, but I'm afraid I never believe homeowners.
I will give that a try now. Thanks for now for your massive help as well as being to fast in responding.
I just agree with not believing the homeowners :)
I just wanted to give you the heads up. The system is working now not as it should but it gets warm. I believe it needs some balancing valves as the property is so huge and cannot cope. However, thank you Dave for your help!!!
Balancing valves Matchless? That's what the lockshields are for!
If that's the case, then you've got another days work balancing it if it's big. It's not at all difficult, just a ball ache.
The only long term prob with balancing is that if the system isn't spotless then the rads closest to the boiler will be shut down so far they can block with debris very easily. I'd explain all that to them so you can do a proper job. Otherwise walk, no run, away :D
If it was me I would have installed a llh and one of these Strangregulierventil TA STAD mit Entleeradapter DN 25 1" - Heizprofis, 67,20 €
That’s what I meant with balancing valves. I would also change the TRVs to heimeier eclipse so you can set the flowrates properly.
IMI do similar and also completely FAB free courses.
Agree that in a world which valued what we do and our knowledge with an eye to the environment then it's a no brainer. However this is rip off Britain... :mad:
The other thing in Britain is that no one would want them seen. #To55ers
Reply to No downstairs heating ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had an electric boiler which heated all the radiators just fine, but around a few years ago i had a gas one fitted and the radiators in the living and...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the flow/return on each radiator so that I can then grab the right pipe to check which heats up first. There has been an extension done on this house at some...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi. A new house regulation for a 2 zone heating system because it's bigger that 150sqm. I'm I right in saying zone 1 should be all of the downstairs radiators and zone 2 all of the upstairs radiators ? I have thermostat room programmer down the stairs and another one upstairs. I think the two...
2K
