M
mmmadman
Hi All
Whats th best method of fitting a flexy to a tap. There are so many different types and I cannot seem to find one with a isolation valve and 15mm compression @ each end.
My tap has 15mm tails, would it be best to compression fit an isolation valve on the main pipwork then use a short length of 155mm into a standard 15mm to 15mm flexy.
Screwfix do flexies with valves on but they have push fit connectors are they anygood, some are just plastic and some look more substantial.
Many thanks, cheers.................
