Discuss new washing machine, unable to attach waste pipe in the DIY Plumbing Forum area at PlumbersForums.net
Deleted member 99918
got a new washing maching delivered this morning (old one taken away).
all was going well with the installation, until i went to connect up the water waste pipe.
the connector that is on the drain u-bend appears to be 23.5mm, but the waste pipe on the washing machine looks like 21mm.
there is absolutely no way that the pipe will fit the connector, and we've tried but all it's doing is starting to affect the pipe so we stopped.
looking around the usual screwfix/b&q etc they all seem to stock the exact same connector that we already have (23.5mm).
how are we supposed to connect up the waste pipe to the drain?
photos attached.
Wont the washing machine pipe fit the spigot in your first picture? if its tight, put the end in some hot water to make it softer, usually does the trick, but make sure you put the jubilee clip on before pushing it onto the spigot.
that's what i'm trying to attach it to, but the pipe is 21mm and the spigot (i assume you mean the plastic connector) is 23.5mm.
i've forced it and forced it but there is no way it is going to attach, it was starting to damage the internal pipe due to the force being applied.
You might have to go for an adapter
or fit a stand pipe.
or alter your trap if possible. Check the size before buying. I don't know what size theses are.
Picture 1, the fitting steps up in size, does the smaller (first) section go in the hose? If yes is it a loose fit and you are trying to get the hose on the larger section?
The adapter you have looks too large. One of these might help
Just use the end bit?
I have never had a problem with them before are you trying to connect it properly
unless there is way other than it being a push fit, then what other method is there?
[automerge]1586610111[/automerge]
that was the one that was in place for the old washing machine.
so i'm guessing the old washing machine must have had a much large waste pipe.
Reply to new washing machine, unable to attach waste pipe in the DIY Plumbing Forum area at PlumbersForums.net
I am installing a sink in utility room. Washing machine waste already exists and is the verical pipe with the flexib pipe from the machine poked...
I have moved our washing machine into the garage but there isn’t a drain for the waste pipe. The attached image is of the waste pipe with the...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs...
R
Hi there, Please excuse my lack of knowledge on this, my plumbing knowledge is very limited. I have a cold water feed going into cistern with...
