Discuss New potential issue! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all me again...
Ok after all the nonsense regarding my boiler tripping out, which hasn't happened since the wiring was sorted out in the junction box and the boiler power lead itself.
I've now woken up to no hot water but lovely heating, I noticed that
1) the pipes out of the cylinder upto the bleed valve , are cold ,after the valve are warm
2) the 3 way valve lever isn't slack anymore it doesn't go past half way.
So the question is , is it an airlock or the 3 way has finally given up, after a week....
I'm done with the thing, new year new system going in.
Was anything other than wiring done
Just replaced the thermostat again, went back to original dial clicker. The 3 way is No longer loose. In fact this morning when I looked after cursing several times I turned the water off and on several times to see if that'd work, there wasn't that usual wurring. I wish I never bothered with these rads now
Not really the point mate. I know you’re frustrated with this but to rewire a potentially damaged three port is stupid on his part
first port of call check the wiring eg your getting voltage when you have your settings and when hot water off your getting voltage where your suppose to
I’m inclined to think the problem is two fold I suspect there is an underlying electrical fault which isn’t obvious and will need a heating engineer confident in testing heating components and voltages to diagnose. In addition I suspect the three port that was there is going to be damaged by the previous poor set up. Don’t give up on the system it’s the engineers I think that are letting you down
I know he was using his voltage tester, lots of beep beeps!. I've got the immersion on for now 2 hours me it goes off!. Is there nothing I can do (without using tools or breaking anything) to manipulate the 3 way to open up to get water flowing?
So the 3 way is locked in the CH position.?
And there lies the problem he was using a volt tester rather than a multimeter. You could maybe take the head off but will probably not be recommended as you’ll probably need to put a screwdriver in the valve head
Sorry it was very similar to this
https://www.NoLinkingToThis/p/megge...sxqmC1ocRZKL0BuREUENV4c9N9WquvYwaAkF8EALw_wcB
Read it but there’s not much you can do fella without another engineer. Think you’re just going to have to badger the last guy
Which of these 2 pipes out of the tank should be cold btw? I know the one at the back is the cold water pipe but what of the other 2, and are either of those valves bleed valve? In case it's trapped air giving me grief?
What do you mean cold?? As in mains cold? Call me daft you have tried opening the bleed valve to see if there’s air
Can’t see one to the right of the valve but the bleed valve above the valve is the one you want
Reply to New potential issue! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
