Discuss New cylinder, New pump. NO HOT WATER. HELP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wright1
I had a leak in my hot water cylinder, i called the insurance, they said id have to replace the cylinder and they would do the rest. I replaced the cylinder and stopped the leak but there was no hot water, the radiators worked but no hot water!
I brought a pump thinking the reason the hot water wasn't reaching the taps was due to a broken pump. Iv fitted the pump. STILL NO HOT WATER.
Its costing me no end on parts and i have insurance people waiting to come and decorate!
any help would be brilliant!
Probably a goosed hw zone valve, if u know what ur doing just test it for voltages.
Timer on for hw, voltages should be....
240v on brown
240v on grey
240v on orange
If no voltage On orange the either the synchron motor is goosed or the valve head needs changing. Hope that helps
Some details of your system and configuration would be helpful. Plus, which pump? circulator or what?
Do you mean you have no hot water or no water coming out hot taps????
do you have water coming out of any hot tap? if not your gate valve might be at fault:)regards turnpin
Sonds like either the spindle on gate valve goosed or just a simple airlock
If you don't have water coming out of thr hot taps at all could be either broken gate valve (replace it with a full bore lever valve), or possible airlock.
If you think it's an airlock, attach a hose to the draw off cock at the bottom of the cold inlet of the cylinder and try and see if you get a good flow of water out. If you don't, the problem is between the tank and the cylinder. If you do, then the problem is between the cylinder and the taps.
Reply to New cylinder, New pump. NO HOT WATER. HELP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had my indirect hot water cylinder removed a few days ago and the central heating boiler and pump is turned off at the fuse spur right next to...
Hi All, I have a leaking drain valve off the CW inlet on a Range Cylinder. Am I right in thinking I have to empty the Cylinder below the CW inlet...
newbie184
N
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi all - hoping someone knowledgeable can help as I'm super confused by this.... I have a standard system / gravity fed boiler, large cold tank...
Deleted member 120897
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
