Discuss new build sprinker system/32mm main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sammathias
I was told today that apparently on new builds that sprinkler systems are required to confirm with building regs and that a 32mm main is required as standard.... is this just a load of hot air or???
Depends on system if no storage yes,
Recently did a new build and it was specced at 32mm, combi boiler there. (Not my idea...)
No sprinklers ever mentioned!
Stu
Never seen anything in the spec or from building control requiring sprinklers on new build houses that we have been involved in yet.
Did some in york last year.
Normal 25mm main to house and separate 32mm main to feed sprinklers.
Reply to new build sprinker system/32mm main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
