Discuss Nerrad tap wrench kit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
nope havent met a tap i cant sort with the jawdropper and the old school wrench
PB plumber you posted up Shaun has all the new toys but I suspect he's getting freebies for advertising them.
Yep he got it for free as he did a vid straight away
I've got the 15 & 22 pipe slices and the stubby wide jaw spanner they're well made bits of kit - although when I looked in their catalogue different products are made to different standards.
Except they keep eating blades :D mine go through a set in a month or two other than that there not bad
https://www.amazon.co.uk/dp/B079NJQ...&ascsubtag=c413d2868dc3d2eb0753ed8c827681e6_S
I want this kit but will feel robbed at £167.00
I do a lot of taps but I have the jaw droppers and monoblock spanners..
I don't own any Nerrad tools, are the worth the money?
Nerrad tools seem to evoke a 'Marmite' response from what I've seen. THey were very popular fro a while but then backed off marketing so have fallen away somewhat.
Personally, I have only ever stuck with tools from toolmakers such as Bahco etc. I do not go for even the likes of Rothenburger anymore as just like the likes of Stanley, they are just too poorly made, too slack, too much tolerance which, on a tight tap nut, is pretty darned important when you're using them as your main source of income generation.
I agree with Shaun here. There's one other thing. If you are changing taps often cos there is a problem getting spares, maybe look at improving that situation. That way the pain in the bum problem of having to 'change em' goes away.
My lips are as tight as our WRAS approval :cool::cool::cool: :D:D:D unlike 70%+ of the taps sold in the UK & 99.973% of cartridges.
Hey I thought I was being perfectly fair!
It's not my place, neither, to be honest, is it right to outright promote. That's for you 'clever' lot - hint hint. :rolleyes:
Aww come on you horrible lot. I was genuinely trying to help. :(
Let's face it we've all struggled for years doing the bl00dy things but thanks to, and I quote, "A bl00dy good bit of kit" it's now a doddle...
Oh, on a course yesterday in sunny Gloucester training Dyno Plumbing lads, someone made a perfect new 3/4" cartridge in 4 minutes 56 seconds smashing the previous record of 12 mins 7 seconds... ;)
Actually scrap that as even though I was one of the first people to see it at a trade show I still didn’t get a free kit:p:p:p:p
But seeing it changed your life - NOT... :cool:
Actually a good point. If, genuinely, anyone is interested in a kit then I'll do you horrible lot £25 off. If you're interested let me know & I'll give you a code.o_Oo_Oo_O
What’s in the kit?
Best oook online tapmedic or
store
What’s in the kit?
Number at start is what's in, number after is capacity.
1 x Aluminium case – lockable
1 x Protection mat (1)
2 x HD polypropylene foam liners (2)
1 x Separate component box (1)
1 x TM® cutting jig (1)
2 x TM® Allen keys (4)
8 x ½” cartridge bodies (18)
4 x 3/4" cartridge bodies (12)
12 x Shroud adapters (50)
14 x Shroud adapter clips (50)
12 x Short flanged head handle screws (50)
6 x Long flanged head handle screws (50)
4 x Short grub screws (spares) (50)
4 x Long grub screws (spares) (50)
8 x ½” body extensions (18)
8 x ½” grey end seals (24)
8 x ½” black end seals (24)
4 x ¾” body extensions (15)
4 x ¾” grey end seals (15)
4 x ¾” black end seals (15)
8 x 18 splines 7.6mm dia 35mm long spindles (20)
2 x 18 splines 7.6mm dia 55mm long spindles (5)
2 x 18 splines 7.6mm dia 75mm long spindles (5)
10 x 20 splines 7.6mm dia 35mm long spindles (20)
2 x 20 splines 7.6mm dia 55mm long spindles (5)
2 x 20 splines 7.6mm dia 75mm long spindles (5)
8 x 24 splines 7.6mm dia 35mm long spindles (20)
2 x 24 splines 7.6mm dia 55mm long spindles (5)
2 x 24 splines 7.6mm dia 75mm long spindles (5)
8 x 28 splines 7.7mm dia 35mm long spindles (5)
2 x 28 splines 7.7mm dia 55mm long spindles (5)
2 x 28 splines 7.7mm dia 75mm long spindles (5)
20 x 3mm handle sleeves (160)
10 x 4mm handle sleeves (128)
10 x 5mm handle sleeves (96)
10 x 10mm handle sleeves (48)
2 x 12omm handle sleeves (4)
You can specify a STD kit in any from 12 x 1/2" & 0 x 3/4" to 0 x 1/2" & 12 x 3/4". Same price.
Oh they also do shower valves too :rolleyes:
How the hell did you get one? Not having you paid retail for that bad boy:p:p:p
Ordered from the website I do a lot of disabled Stuff eg changing to lever taps and repairing
And I did no special discounts
In short it works out around £15 for the 1/2 and £20 for the 3/4 each fully
Really? We designed it to be £15 per valve in a kit. :confused::confused::confused:
1/2 one is around 8 a valve plus about 3-5 for the extras
3/4 one is around 10 a valve plus about 3-5 for the extras
Is the adhesive any good?
Oh gosh I'd forgotten about that! Hell we changed from that ages ago to a more robust, faster, safer and more reliable method. Its all now, genuinely, a piece of cake - hence the record time. When you saw it we had to wait 10 minutes for the adhesive to go off!!!
We did 140 odd demos whilst we were at Installer. 1, just 1 out of all of those people mentioned it being 'faffy' and it struck a chord with me. So 6 weeks later I'd redesigned it to what it is now and even I am happy with it :eek::eek::eek:
I'm lost :confused: :D
An early version Shaun. We used to use adhesive to glue in the spindles and to glue on the shroud adapter !!
I see glad it's not that type as I personally wouldn't of bought it
Wouldn’t be surprised if the person that mentioned it being Faffy was me. I did say I was one of the first to see it. Was quite interested at the time. You even wrote my details in your diary. Was really quite sad when I wasn’t contacted.:(:(
But did you chase him up
Hmm. There was some 'internal disagreement' about the keeping quiet thing. Lets just say, "That's no longer our strategy."
We expected to be launching quite quickly but it was nearly 18 months before we were able to properly do so. Getting those ducks in a row is like herding cats - that's the single most awful mixed metaphor ever!
Smarty pants :D
We are all endowed with 20:20 vision, but at the time it was all we could come up with. To be fair tho, we still had huge amounts of interest - especially the big boys as it would still have saved them shed loads of time (money).
Didn’t mean for it to sound like that mate(sorry). Always sceptical with stuff like that. That’s why I do not use his stuff.
What do you use now then?
Reply to Nerrad tap wrench kit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
