Discuss Needing some help - no plumbing knowledge in the USA area at PlumbersForums.net
Les
Hi - I'm new here. I have a Glow-worm flexicom hx boiler that had a f25 error code and isn't heating my water. I have bled all the radiators, then reset the boiler and now have a f22 code. Can anyone offer advice please. Thanks.
Sounds like you got a pressure fault/pump fault/ type of issue, maybe sludge in the boiler, in any case you’ll need to get a gsr to take a look inside, fairly straightforward for an experienced guy once you get the lid off.
When you bled the radiators did you re-pressurise the system?
Reply to Needing some help - no plumbing knowledge in the USA area at PlumbersForums.net
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
The flue for a glow worm micron 30ff is apparently obsolete but there must be other flues that would fit it surely, it's just a standard 100mm...
I have a Glow Worm Ultracom 30sxi boiler that provides central heating and also heats a hot water tank. There are no error codes shown on the...
3K
I
Hello everyone, I have a glow-worm 24ci which was working fine and has now decided that it doesn't want to heat the water. By this I mean that...
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
