Discuss Need to join to an old 20mm plastic pipe in the USA area at PlumbersForums.net
Is it grey pipe? And it’s the water supply to the toilet ?
I’ve a customer with combi boiler works fine and provides heating upstairs but downstairs is cold, isolated all rads upstairs boiler goes out on overheat, there are some stuck trvs on downstairs rads but on releasing pins still no circulation, I’m thinking sludges rads
any other options
any other options
Hey roger, you sure you meant to post here?
Hi yes it is grey pipe supplying the toilet.
Sorry to say it’s not an easy job it’s polyork and it’s imperial in my experience it’s too brittle to do anything with they sell adapters but you normally find / end up using a philmac utc or repipe
Reply to Need to join to an old 20mm plastic pipe in the USA area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
