Discuss Need help finding a fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thedog123123
I just moved into a flat with a 1.5 kitchen sink (1 1/2 pipes). The waste pipes are setup similar to this picture here:
Sadly, the piece that is circled was cut to short by over a 1/2 inch so it doesn't fit well into the bottom part of the piece. I went to try find a connector like that but I couldn't find one. I did find something similar but it has a male attachment at the top not a female which I need to connect to the sink basket.
w2w.diy.com/departments/floplast-waste-trap-height-adjustor/152689_BQ.prd (change the 2 to a w to view link in www)
I am a novice with plumbing and any help would be appreciated
take that picture to a merchant buy the whole thing keep the bit you need and bin the rest, you cant get the adjustable pipe separately
as above you'll need to buy a whole new trap or get a trap extension piece if it'll fit although i prefer less joints where possible
Trap extension piece for a kitchen sink (1 1/2") will do no problem
Reply to Need help finding a fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
