Discuss My new kitchen mono tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full throttle. Also when I point tap to bowl with fairy liquid in, it doesn’t have enough power to make bubbles
Do you have a gravity cylinder eg copper ?
So should be equal pressures within reason
Isolation valve party close ?
Reply to My new kitchen mono tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had a plumber fit a new mono block kitchen tap. The water runs very slowly now. Also, not sure if this is to do with it, but my hot water...
I have just replaced the old bathroom basin mono mixer taps, 2 tap heads, standard compression valve type, to a modern mono mixer single lever...
3K
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
I’ve cleaned the grooves and tightened the grub screw at the bottom, but this tap handle (on the right of the photo) just won’t stay put. When...
