Discuss My New Hot Water Pump (Evosta 3) is over pumping in the USA area at PlumbersForums.net
Hi, I'm a DIY plumber and new to the forum, and would appreciate some advice.
I have an oil fired boiler heating a smallish house. I just took out my old (20 years) copper hot water cylinder and replaced it with a new stainless steel Indirect Unvented cylinder.
The old system had a pump on the central heating (still there) but no pump on the hot water circuit, and it flowed pretty well via I assume the principles of hot water rising. It is a very short distance from boiler straight up to the cylinder.
With the new cylinder however it just would not flow, so I had to fit a pump, namely the Evosta 3. I'm sure it is a great pump, but it seems just over the top for the job, to the extent that even on the lowest pump setting it is pushing water into the vent.
Is there a known fix for this, eg do I have to add another pressure tank, or is there another setting on the pump to reduce the head (and hopefully make it quieter). Any ideas welcomed. Many Thanks.
Any pictures of the install ?
Pictures and a diagram of pipework would be useful.
You need to be G3 registered to fit unvented cylinders !
And pumping what is basically a gravity circuit is a big no as well.
Hi, I'm not sure they would help.***.the pump is on the return pipe, 1m above the top of boiler and 1m beneath the bottom of cylinder on the floor above
Can we have some please
Hi, Pictures attached.
In answer to an earlier well made point, I am guided in all of this by a professional plumber. The current plan is to add an expansion vessel, but I/we would welcome other thoughts, and if anyone knows why a gravity fed system that worked fine for years now won't flow with the new cylinder, that would be interesting too! Cheers.
Because your feed and vent placement is wrong it’s set up for a gravity hot water system (teed into the cylinder return and vent off the flow)
You've basically put the cylinder on the gravity circs, I really hope you've installed the two port valve as per the manufactures instructions. It would never work on gravity as it isn't designed to, they are for fully pumped systems only.
As other's have said the system needs converting to an S plan system, with motorised valves for heating and hot water, the Feed and Vent correcting.
What starts/stops the Evosta, Paul?
That pump should also display the Head (M), the Flowrate (M3/hr) and the power ((W), what are they?, Night give some clue as to reason for pump over apart from the other stated reasons.
One reason for your new cylinder not performing on gravity may be that it has a corrugated coil.
As mentioned above the position of the cold feed and vent is on the old gravity circuit. No matter where the additional pump is situated on the HW flow or return you will get pumping over.
You need to remove the pump, convert the system to an S plan and either repipe feed and vent or seal the system.
Hi John,
The pump is controlled by the cylinder thermostat, currently set at 55. The pump is set at the lowest rate I could find......6W, 1.1m head and 0.5m3/hr, sometimes showing a little higher.
My thanks to everyone for the generous and clear advice. I'm sure S plan would be the best solution....given where I am would another be to remove the current open vent tank and add an expansion vessel to the hot water loop?
You have to go s plan for a unvented there’s no ifs or butts
But the plumber doing the unvented should know this so suspect diy
Thread closed due to you need to be qualified to install an unvented else it’s a bomb and your home insurance is invalid
Reply to My New Hot Water Pump (Evosta 3) is over pumping in the USA area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
My son has just had a new boiler fitted and hes noticed that the pump runs 24x7 even when both the heating and hot water are set to off. He’s...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
