Discuss My double flush toilet has developed a fault. It won't stop filling eve when I pull the float arm right up. I have replaced the inlet valve diaphragm in the USA Plumbers Advice area at PlumbersForums.net
My double flush toilet has developed a fault. It won't stop filling eve when I pull the float arm right up. I have replaced the inlet valve diaphragm but this has made no difference
What else can i try?
Replace the valve as the diaphragm has not been fitted properly.
There must be water coming from the pin so that it builds up pressure on the - side of the valve so that it shuts off
Reply to My double flush toilet has developed a fault. It won't stop filling eve when I pull the float arm right up. I have replaced the inlet valve diaphragm in the USA Plumbers Advice area at PlumbersForums.net
