Discuss Motorised valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbingdazman
I need to replace the head on a tribune he range 22mm DHW 2 port motorised valve as i have to hit the top of it to get it to open to allow hot water from boiler through to heat the cylinder.
Can i get something from honeywell or other brand to replace this or is it best ringing up range spare parts hot line and get another one from them.
Or is there something else i can try before i order a new one.
Darren
it might be the sychron motor that needs replacing . I would not recommend hitting it as you should be able to set it to manual with a lever on the side
If i turn the red cog on the side so it starts to move it continues all the way around until
it gets back to the start. ( in other words it does not stop where the cog is flat) but when
i give the top or side a bang it goes around then the boiler kicks in when the cog stops on
the flat part.
Trying to find a photo now.
Looks like a standard tunic two port should be able to get it easy enough. You will need the code off the head before ordering. Try held they will b the cheapest.
looks identical to the Danfoss 2 port head.
if i were you tho, id be draining down and changing it for a honeywell 2 port. much better and easier to repair in future. wiring simple, if problems you can refer to honeywell compatibility charts or phone them to get wiring comparisons.
Still reckon its a sunvic the wheel with a flat is a giveaway Danfoss has a lever
If you do change the whole valve and not just the head....fit a Honeywell. They're just better valves.
Reply to Motorised valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have tried hard to get similar to the first class satchwqell /Sunvic SML type revolving type valves instead of the quite short lived spring...
N
Range Tribune HE, not heating hot water. Motorised valve keeps closing and water luke warm. Is the dual temperature probe broken
Neil Pengilly
N
Deleted member 120897
When either of the 2 port motorised valves closes, I get a loud clunk. A Honeywell automatic bypass valve was fitted a year or so back to replace...
2K
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
