Discuss Monument 362W Pipe Ready Chrome Remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 96286
I've got 16 TRV's and rads to change over and move and every one of them has pipe with the dreaded white paint on them, and some will need chrome removed from the pipes for soldering. They will not be going back exactly in the same place, so the pipe will need prepd and the paint removed first before making new connections, some of which will be soldered, and the towel rads are going back in new chrome pipe.
Rather than getting the file/gas torch/footprints out and around the pipe, has anyone used the tool in the post's title from Monument? This is one chore I find annoying and looking for a quicker solution.
Grinder and a sanding pad
Reply to Monument 362W Pipe Ready Chrome Remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
