Discuss Missing one trap or two? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My first post here.
So builder has finished his work but I think a trap is missing from the wash basin and the washing machine waste. Which explains the smells that come every now and then.
I'm thinking I could add an inline osma siphon to each or one shared between the two. Or an s trap shared.
I've attached a photo. From the right side the pipe coming in is from the wash basin which has no trap.
Any pointers? Or best to call a plumber.
Can you take a picture of the other side of the wall please, and builder you say??:p:p
Get the builder to get a plumber and tell him to stop messing around with plumbing
As above we could do with a picture of the other side but if it was me I would repipe and fit a washing machine trap and anti vac trap on the basin
It's just the wash basin with nothing under it. I could take a better picture tomorrow, this is what I've got on my phone at the mo.
Cheers all and a happy new year when it comes
You can do lots of things, but simple answer is what Shaun said. Osma waterless traps (i.e. HepvOs) really are very good for solving problems, but are noisy and will, I expect, eventually wear out. I've nothing against builders doing small bits of plumbing work, but your builder has not the basic knowledge of even a DIY manual/Google search. If he really can't be bothered even to do that level of research, he really should get a plumber in, and I don't say this very often.
Oops. I now realise that shiny thing under the basin is a trap. Doh! So I've added the s trap on to the other side so I can add a washing machine waste pipe and I think that's it!
You will need a stand pipe (going to roughly the same height as before)
Also the pipe looks like 11/4 (32mm) ???
...because a sink and washing machine need 1 1/2" waste pipework. Anything less is below industry standard and will probably cause trouble.
Reply to Missing one trap or two? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi, I have an issue with the standpipe trap in a 3-year-old flat. This flat came with a fitted dishwasher that has been completely unused for that time – until now... The weekend before last, I thought maybe it was about time I tested it out running empty – it all worked fine and it drained ok...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
Hi there, Apologies for the mammoth post but my neighbours and I really need some advice... I recently purchased a flat that was built in 2016. The apartment is still under the NHBC 10yr warranty. Since moving in, I discovered that the rainwater pipe that runs through my winter garden balcony...
Hello, purchased a house in February this year and for a few weeks, noticed a loud banging noise which sounds like it is coming from under my sink, but happens when no water is running. I think it could be when my neighbour is either running water or maybe using a washing machine. House is an...
