Discuss Megaflo regenerate air gap? in the DIY Plumbing Forum area at PlumbersForums.net
Hi all,
Megaflo 300i in the loft. I noticed the overflow was dripping and also the tundish. 10 second google and lots of instructions how an average user (I'm very average) can recharge the air gap. Followed to the letter:
Closed mains feed to megaflo
Opened lowest hot tap. It drained pretty quickly.
Opened TRV (actually called T&P release valve)
At that point nothing happens - no water flow through tundish, and no gurgling.
Put all back on and it's not dripping but as I didn't really do anything, it can't be fixed can it?
Shall I just leave it till it goes again or is this impending doom?
Thanks for any advice
You need to grip it, turn in anticlockwise enough that it opens and starts sucking, and then keep it like that for about 10-20 minutes. If you turn too far (more than about 30° IIRC) it'll clunk shut again.
I suggest you wear a thick working glove on the hand you use to hold the valve open because the spring is pretty strong and otherwise, unless you have plumbers' fingers, you'll be in quite a lot of pain by the time you've finished.
Thanks Chuck. It was pretty easy to turn and stayed in the turned position - does that suggest the spring is a bit knackered?
I checked what work was done on the system and in 2019 it had a new TPRV at least that's what the job sheet says, so it should be OK
Hi Scott, No it's normal vertical but I did it again following what Chuck said and turns out I was a bit limp when turning the valve. It needed a good hard grip. And now my hand hurts after 15 mins+ of holding it so looks like it worked! thanks.
Reply to Megaflo regenerate air gap? in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I replaced the Pressure and Temperature relief valve on my MegaFlo CL300 (I had thought it was dripping but it turns out the overflow drip...
I have a megaflo unvented cylinder on the first floor of my property and I am trying to recharge the air gap. I have turned off the incoming cold...
4K
Hi issue: No water from hot taps being fed from megaflo. Was having HW pressure issues, obvious from no flow in attic but very low flow on...
5K
  • Locked
I noticed today that the pressure gauge on my incoming water supply was showing over 5 bar and creeping up fairly rapidly until it went past 6...
7K
  • Locked
Hi, 1st time poster here, hello all! Recently moved into a property with a Megaflo system, started to have problems a few days ago. Hot...
3K
Ermintrude
E
