Discuss marcrist dust extrection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
carrpaul
any body used used the marcrist dust extraction unit for ddm core drills ? are there any limitations with having this fitted to the drill ,size ect , and how good is the extraction , where dose the dust go .
Reply to marcrist dust extrection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
