Discuss Manually turn on central heating when wifi down with Nest ? in the Central Heating Forum area at PlumbersForums.net
My daughter's wifi has gone down, all of south west London Virgin users have no wifi for past 3 days due to someone cutting a cable.
She has just moved into a house with Nest installed and is using underfloor heating to get heat.
Does anyone know how to manually turn on the heating with the Nest.
I know nothing about Nest but am visiting her tomorrow and hope to be able to help.
Best wishes Merry Xmas
Just press large button on the link box - not the thermostat. This switches on both heating and hot water and ignores timer. Press it again to switch it all off.
[automerge]1577039011[/automerge]
Just to update
press the big button marked nest on the link box in the attached photo. The colour of the light changes.
Press it again to switch back.
N.B. need to do this manually as it does not use the timers
[automerge]1577040536[/automerge]
Further thoughts are the system will possibly work with no problems. You won’t be able to change schedules using pc etc but even then you might be able to change these using the nest thermostat.
I gave you worst case above which will work provided the link box is working.(Uses hard wire)
Reply to Manually turn on central heating when wifi down with Nest ? in the Central Heating Forum area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
N
Hi! We're looking for a consult for our 1905 built (renovated in 2010) victorian house for the future of our heating system. The house is 2...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hi all, I was wondering if someone ever heard of a system boiler programmer with WiFi. My niece lives in social housing and has gas central...
Deleted member 120897
About 4 weeks ago my nest stopped being able to turn on or off the central heating on my glow worm 38cxi. As the boiler looked otherwise fine I...
6K
