Discuss Mains Stopcock has been replace by my builder, is that right? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You better of turn water from street and change the head of the valve but keep body in , this is possible if a your old stopcock is not the one that is fitted to lead pipes
post a picture and I can advise you what to do :)
The way I read the fact sheet, ball valves are permitted, but backflow protection is also required. Therefore a separate checkvalve needs to be fitted, if a ball valve is used.
I mention this as I was hoping to replace my old stopcock with ball valve without having to change any pipework. No such luck.
Backflow protection is not required in a normal domestic house at the point of entry, point of use protection is required. In multi occupancy properties with a single rising main where backflow could occur from higher to lower properties protection is required at all but the lowest property.
Although a loose jumper stop tap will function as a primitive back check valve it is not recognised as such within the water regulations.
Thanks for offering, but it's done. I just replaced with the same type with the flow direction arrow on the side.
All sorted for another 30 yrs, till I snap the handle off again.
Well done ! Now turn it on fully and then go back 1/4 turn !
Also if you turn it of and them on every year
Reply to Mains Stopcock has been replace by my builder, is that right? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
PSxxxxxx
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
