Discuss LPG to natural gas conversion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Robert Tyrrell
Just got a job to convert a Vaillant (Can't remember what model but it's fairly new) from the existing LPG to natural gas.
As I haven't done of these conversions before I thought that I'd ask if there's anything I need to know before hand, apart from the model of boiler that is.
Is it just change the gas valve or do I have to get a particular kit?
btw - they have had a gas meter installed and the boiler is, at present, connected to the LPG tank but they're almost out of LPG and don't want to refill.
Check the gas pipe sizing as you can run LPG pipes further at a smaller size so chances are it will be undersized.
Thanks for that but I kinda anticipated that, and its a new meter with no pipe attached, at the other side of the property. I've worked out the gas pipe size, it's just the tech stuff on the boiler change over that I'm not too confident on.
Ask vaillant... On the old ones you could just adjust in the gas valve the co2 levels & put a different sticker on the data plate but I think the newer ones its different, possibly a new gas valve as you say!
i converted a new vaillant boiler to lpg recently. All you do is adjust gas valve. you can pay city plumbing £8 and you can get some instructions on how to do it.
Thought Vaillant had stopped anyone from converting there boilers, they have there own chaps do and charge £150 to do it, all ways used to do my own but for some reason Vaillant won't let you do it.
I called Vaillant today and they told me that it was in the manual. The guy said that I could do it myself but didn't even check my GSR credentials
Reply to LPG to natural gas conversion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed. We have a 1950s foldaway Cannon Gas Grill which is on the...
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
